After a node failover and during filter reconciliation, the specified block filter was found to not be in sync. As a result, the filter was deleted.
There is no remedy because there is no problem to be resolved. This message is for informational purposes only.
Info
Found VSM block filterid %fid% for %slotPort% unit %unit%, not in sync deleted
| Name | Type |
| fid | uInt |
| slotPort | SlotPort |
| unit | uInt |
